MERC 165 OUTDRIVE QUESTION
Sean165
Hey guys, im new to owning a boat, so heres the problem. Shifting into forward is no problem but clicks from lower unit as it engages. But when i try to get her into reverse it clicks loudly from the lower unit, it will eventually start spinning the prop but clicks all the way to about 1500rpm. i checked the throttle interupt switch and that was fine, any ideas..Thanks
JB
Re: MERC 165 OUTDRIVE QUESTION
Moving to I/O
J.J.W
It could be as simple as a shift adjusment, or its possible some of the shifting parts are getting worn out.<br />Here is a link to a Mercruiser Service bulletin on alpha shift problems.<br />www.sterndrive.cc/pdf/shift.pdf<br />Good luck,<br />Justin Webb<br />www.sterndrive.cc
