Re: merc 1967 9.8 110 model ,no water at exhaust port
Pulling the lower unit off and blowing air (or circulating water) up the copper water supply tube will tell you everything you need to know. Your motor may be plugged-up and not getting circulation inside. You could pull the cover over the spark plugs and see what's going on there. Just be careful, if it's been in salt water you'll need heat on the bolts to get them loose.
BTW, are you in the water (or in a barrel) when you're running the motor? Otherwise not much water gets forced out of the exhaust relief ports.
Another good indicator of water circulating thru the powerhead is to feel the exhaust manifold cover with your hand while it's running. If much above lukewarm you don't have sufficient cooling to the upper end.
And yes, upper water tube grommets are a common problem, however, I'd think that if you get lots of water out of the flushing screw (I assume you mean the one right below the powerhead splashpan/cowling), water is at least finding its way up that far. However it's still possible to have obstructions to flow past that point.
Least invasive is to pull the back cover, so if you get an indication of poor flow when you run air or water up the water supply tube, I'd start with that cover.
HTH & G'luck.......ed
