Re: Merc 2.4 V6 lost wot power
Agreed but the compression is spot on, 115-120 range with less than 5% difference. Eyeball through the sparkplug hole shows normal looking piston top.
I am starting to suspect a heat related ignition failure, would any one know of a test for coils that doesn't require special equipment. I have a super hot blow dryer type gizmo and a volt ohm meter but nothing to measure output of a coil, could it be checked on the input side.
Ideas???
If the plug isn't firing, it'd be pretty oily and wet with fuel.
Run an induction timing light from that plug while underway. If the coil fails to fire the plug, the light will also fail to fire.
You could also watch the primary side with a portable oscilloscope.
If it fails, then start playing musical coils till you isolate whether it's the coil or the switchbox.
1 plug fail, coil or switchbox
2 plugs fail, opposite in timing, like 1-4, trigger
3 in a bank fail, switchbox or stator
other combinations----crap shoot.
hope it helps
john
