Merc 200 1981 control box removal - can't get off!!!
RVAHA
I just purchased a 1981 Merc 200 with a concealed (panel mount) control box. I am trying to remove the box and motor and install on another boat. I've removed 8 screws on the outside portion of the box (the part close to the driver). However, I can't figure out how to get the handle loose to seperate the units apart. Any ideas?????
RVAHA
Re: Merc 200 1981 control box removal - can't get off!!!
I going to try and get a manual. Not sure if it will have any details.<br /><br />Any Merc-experts out there??<br /><br />Thanks
Walker
On the backside of the box there is a bolt into the control arm center. Take out the bolt, stick a punch that is smaller diameter than the bolt into the bolt hole and give it a good rap with a hammer. The control arm will come out and you can split the box then.
RVAHA
Walker, thanks I'll give it a try.<br /><br />I have looked extensively at the back of the box, but have not seen a bolt. As you know, there is very little space to see. (crane the next sideways!) I did take loose a metal and plastic cover on the back. <br /><br />I take another look,<br /><br />Thanks again!!,<br /><br />Rick
RVAHA
I tried again tonight to get the control box apart. Still can't find any bolt. I did see a red plastic cap. Actually, I pried on it and found out that it is a bushing. It appears that the control is pressed together. It has me stumped!<br /><br />Sure could use some help!!!! I haven't gotten a book yet, but am going to try and find one soon. Would a breakdown of the box be in the book???<br /><br />Thanks for any help!!
RVAHA
Any ideas???? :confused:
RVAHA
FYI -<br /><br />The shift lever and box has a small opening at the bottom which has a set screw in it. The lever must be in neutral to access the screw.<br /><br />Rick
