Re: Merc 200 20hp testing stator help.
Its only coming out when im squeezing the primer bulb. which would force the float open, I just tore the carp apart and cleaned everything out, ill give it another try tommorrow. i just need to make up a new gasket for the flange to the motor.
If anyone has a good parts list that show all the parts, i would greatly appreaciate it. My Carb is a KA.25P, Is there a newer carb available that i could illiminate the fuel pump. Its working ok for now, but its just something else that could go wrong.
This motor is really disapointing me. I got it on a trade for a gun, and the first day on the water it started on the first pull every time, until about 2 hrs later, and it died. i got tired of pulling it to troublshoot it, and stumbled onto a rate electric starter for it.
I cant thank you enough for all your advise, but do you have the info on how to properly set up the timing?
Where can i get a good service and parts manual for it. from what ive found on the net, i believe its a 1970.
