shelbydriver
- Joined
- Dec 13, 2002
- 173
Hi, a just got this motor and it will not run in gear over 1700 rpms. It runs up nice to 5k or so in neutral in the water of course. I just replace the fuel diaphram but have not test it yet. I did check for water in the gas separator and did not see any. Swapped filters. Maybe high speed jet clooged? Could it be some kind of stator problem not giving spark under load? I think the batteries were weak. umm oil injection has been disconnected and have not check the compression yet. The diamphram for the fuel pump did not look too blown out or anything. What should one look for in a fuel pump diaphram? Any ideas will be greatly appreciated. I looked at the pick up on the tank and did not see any check valve. Just a L angle fitting. Can I unscrew that without breaking it off. I hate to have to saw the floor up to get the 90 gallon gas tank out. I can see big problems there lol. A toast to the boat maker who did not put hatch for gas tank removal. Cheers and beer for you.
