shelbydriver
- Joined
- Dec 13, 2002
- 173
I hear the warning buzzer sound as low as 160 temps on the gauge. Subject, 200 94 carbbed merc xxl. I put in the new lower waterpump housing, impeller, head gaskets,thermostats, new water hoses, poppet valve. last testing has it running cooler than before. Hmmmm could it be the gauge or sending unit? Is that buzzer also a fuel warning? aahhhhhhhhh some one help me? Thanks. I cannot locate my friends with a temp infared pointer or the chalk heat temps sticks neither. Seems to run cooler with engine out of the water some rpms up.
This testing is getting expensive at wot 20 gallons per hour.
