Hello,
Recently I discovered my left cam shaft (looking from the back of the boat) is not getting any fuel. When I pump the gas line and press on the bead attached to the cam shaft only air comes out. However, the right side shoots gas out when I press on the bead. Anyone know where the problem is ? Thank you ! The boat will start briefly then shut off.
