(Model F25ELPT, serial 0r374682) With thermostat cover & thermostat removed as well as lower unit off I can't get water to flow up the water tube. One of the ports under the thermostat cover seems to be blocked as well, I suspect a blockage around the top of the water pipe causing the issue. Water nor air pressure will free the blockage from either end. A coat hanger up the water pipe reaches all the way to the block and sounds like its tapping the block. Any ideas were to start? power head off or alternate recommendation how to find the blockage? Other posts suggest the rubber grommet at the top of the water pipe imploding due to salt water, power head off to explore this theory or is there another way?
