Okay, i have a merc 260 (5.7) with the stock Rochester 4 barrel in a 1985 Sea Ray Sundancer 260.
When I bought the boat last month, the previous owner said that he had rebuilt the carb about 12 months ago, drained the fuel tank, and has not used it since.
So, I finally got my boat in to the water. The idle seemed low and had trouble keeping the motor running, so I adjusted the idle.... I got it upto about 700+/- 50, but the engine rpm was a little sporadic, jumping up and down about 100 rpm. It would smooth out at about 900-1000 rpm.
I I adjusted the fuel/air ratio best I could by ear, and decided to bring it in and have the shop adjust the fuel/air, as I couldn't get the idle to smooth out.
The mechanic adjusted the fuel/air screws twice (i watched him so i could make sure I was doing the right thing). He couldn't get it to smooth out either. He said that these older carbs are commonly like this, and that I shouldn't rebuild it, just buy and new one with a warranty from him.... at a price of about 650 to 700 bucks for parts/labor. I kinda felt like he was just trying to push the sale.
Anyways, so, today I get it back on the water, and it is idling around 650-750. Running well. Then, after our 8th or 9th restart, it would not hold idle and I had to bring the idle screw in about 1.5 turns to start it. Then, backed the idle screw out to about 750 rpm. Went through that about 2 times today. I have to keep adjusting the idle screw in, raising the idle, then adjust it back out.....after the motor runs for a couple hours I have to do it again.
It almost feels like the idle screw is coming/vibrating loose/out and allowing the idle to drop too low, to the point it stalls. Anyways, I'm not too familiar with these systems....so i was hoping that someone might be able to give me some advice here.
I'm pretty mechanically inclined and am not afraid to tackle the job if someone can point me in the right direction.
Does this sound like a problem that can be fixed, or should I start saving for a new carb?
