merc 260 engine oil?
boatman37
so what oil should i be using? the merc manual suggests straight weight but if straight weight isn't available the 20W-40 would work. but it doesn't specify which straight weight? 40 SAE? 1986 sundancer 250 merc 260 I/O
Bt Doctur
Not another oil thread
15W-40 by mercury, Rotella, Valvoline, etc. 20W-50 is also a good running oil and a bit of MMO
wrench 3
Oils have changed a lot over the last 30 years. Mercury Marine now recommends 25W40 for all previous years of Mercruiser engines.
You can find straight weights, just need to look.
I find it on line and can have it delivered for the same as going to get it. Use straight 40W in 454, and 50W in cruiser. Starting to use Brad Penn 50W from Speed Way and the cost is great.
Prior, found 40W at NAPA, WalMart and others.
My thought is multi weight is great for engines which need to be fired up when its cold. Straight weights are best and I don't fire a boat up if I have to put a coat on
Ayuh,.... Plain ole Shell, Rotella T, 15W-40 here, for the Whole Fleet,... right outa the big red drum,....
wrench 3
Just for the record, that's what I use but it's not what Mercury recommends.
boatman37
ugh...lol. didn't mean to open a can of worms...lol. i actually bought straight 40 so hope that is good?
Im like Bondo. Rotella 15W-40. However i have it delivered via amazon once a month. I dont gave room for a 55 gallon drum
flipbro
I like to add a zink additive to my rotellia 15 40 in my flat tappet camed engine. Most all oil has very low zink these days witch isn't good for our older flat tappet camped engines. Just my thing.
boatman37
well i returned the SAE 40 and got the Shell Rotella 15W-40. haven't changed it yet but thats what is going back in it. thanks!
I would suggest sticking with Brad Penn straight 40W, that is unless you go boating when you need to wear a heavy coat
boatman37
i agree about not needing the multi-viscosity in a summertime toy but the concensus here was for the 15w-40 so...
also, my manual says 5.5 quarts and they only had gallons and then 1 single quart so i was still a quart short and was having trouble finding another quart of straight 40 locally so it was easier to get the 15w-40. and my local auto zone has the same shell rotella there.
on another note, had trouble finding replacement belts locally so ordered them here on iboats. should be here thursday. taking it saturday morning to get a new camper top made for it.
jimmbo
That is wise, as most people don't realize how lacking in EP additives the new oils are.
QBhoy
Quicksilver 25w-40 synthetic blend for me. Seems to be in much better condition at the end of the season in comparison to the old QS 25w-40 mineral.
Also seems to have a better and more prolonged oil pressure at lower revs.
