Going to be a little long, but please stick with me, I really need the help.
Boat has sat for about 8 months, cleaned it up getting it ready to put in the water. All fluids looking goof, fuel still good. Attached the muffs and went to crank it up, turned right over but wouldn't fire up. Checked spark, it was good. Pulled flame arrestor, carb is dry. Figured clogged fuel line. Pulled fuel filter under pump, in good shape, filter by carb in good shape. both were wet. Figured float on carb might be stuck, but by this time had drained battery to low.
Charged battery over night and put back in boat. Went to trim down to hook up muffs and trim switch stopped working. Pulled handle apart didn't see any issues, put it back together since my real issue is getting it running.
Hooked muffs up, turned on the blower to run for a couple minutes the turned the ignition. Instantly everything stopped like the breaker was tripped. I checked it, and it was fine. Thought it might have been the fuse on the starter. Didn't have anyway to check that, so started to put everything up for the night. After about 20 mins for the heck of it, I went and flipped the blower switch and it worked again??? Tried the ignition and same thing, all electrical power gone.
I'm at a loss now. I have no idea what would clear after about 20 mins. It has done this 4-5 times, all electrical comes back to life, but soon as I turn the ignition it kills everything.
Any insight would be greatly appreciated!!
