I have a 3.0 Mercruiser on a 1996 192 RS Stingray. A couple of weeks ago we were out and every time I punched the throttle forward I noticed a small ?bog? or loss of power. The engine seemed to step up and run fine after the slight hesitation. A week later we were out and we got under way. The same thing happened but the boat ran fine. We stopped for awhile and started it back up, got going and then the engine lost electrical power.
I snooped around and saw that the ignition fuse had blown. I rooted around and wiggled the wires @ the ignition fuse, replace the connection @ the battery terminal for the power supply to the GPS (totally independent from the ignition circuit) because I saw corrosion. I replaced the 10 amp ignition fuse and started her up again. Punched the throttle and the thing bogged and after about 100 feet the fuse popped again.
After a long tow home and vicious sunburn I got into the wiring and started to clean house.
-Replaced ignition switch ? Broken terminal
-Cleaned all grounds on engine block and @ battery ? corrosion
-Replaced fuse bus and ground block attached to the bus ? corrosion
The engine ran fine at idle in the driveway. I thought that I had the gremlin out of the boat. We got it out on the water and ran it for about 20 minutes WOT and got to the ramp picked up some passengers and 100 feet after we left the fuse popped again. Same issue under the same circumstances. Engine gets warmed up then it falters and blows the fuse.
After doing some research I have found a common issue with owners of boats with this motor and its ignition fuse popping. Nobody has seemed to find a particular cure or fix for this.
There are a lot of suggestions as to its cause.
The purple wire coming from the ignition switch having to much draw.
I.e. gauges, accessories or powering engine components.
The starter - breaker installed - kept fuse from blowing a few times but it still stalls out and it eventually exploded the fuse and melted the terminal.
Distibutor - How do you diagnose this?
Starter slave solenoid - How do you diagnose this?
Choke - ?
The Alternator - Battery stays charged and all components work fine. But could this be the problem when the engine is @ higher RPM?
Hydraulic trim pump - disconnected trim pump - still blows
Trim sender - disconnected trim limit switch - still blows
Shift interupter switch - ?
Seems to idle fine and only blows when the engine is under a load. After the engine has run for awhile and warms up, higher RPM?s start the issue. After that the fuse just keeps popping until you let is sit for awhile. I am tempted to rip every wire off the boat and start over @ this point. Sombody stop me.....
Thanks in advance
Tayler
Choke - ?
Thanks in advance
Tayler
