Hey all... Dad just got a 1988 stingray 17.5 with literally 90 hours on it. It looks showroom new. However, we quickly noticed more water in the bilge then we expected and after drying out and digging in we founds the culprit. Water is leaking (a light flow) right under the center of the inside transom plate area. Seemed to be slightly more when engine was running while docked at slip but still leaking when engine off. Tomorrow we are going to pull boat out and and run with muffs to see if it still leaks. Will also check transom for soft spots around the housing.
Any other first things to check?
thank you!!
thank you!!
