cheburashka
- Joined
- May 28, 2005
- 715
This is a '74 Mercruiser 140 with Pertronix ignition. Timing is good. Up until yesterday it ran great, with the only problem being a bogging down when coming off of idle. Yesterday, it started running rough out of idle and all the way up to 3k. At that point, the engine will stumble for awhile, then suddenly smooth out and run fine all the way through the RPM range. It does great at WOT and the idle is smooth as can be.
I plan to pull the carb and check it out. It was rebuilt last summer, but something could have gone wrong in there. Any other suggestions as to how to proceed with this?
Thanks
Thanks
