Hi all.
I am new to these forums. Excited to be a part
I am working on an engine/drive removal and swap.
I bought a donor boat (Caravelle 21') with an 888 combo (302 with 888 drive)
The engine is pretty tucked back in the Caravelle. I am having a hard time seing much.
What do you suggest to remove everything? I believe the drive gets pulled first which is easy.
The engine mounts on the front/side gets removed.
Thats where I need some guidance. What else do i need to unbolt, pull off etc... to get the engine out.
I started pulling an exhaust manifold to see better back there but it is proving to be difficult.
I do not want to have to chop up the donor boat. I will be giving it away after I am done.
Thank you all for any and all help
