Hey guys, I have been a outboard guy in the past, and picked up my first i/o a few weeks ago.
1987 wellcraft 210 classic, 305 thunderbolt iv, alpha 1 gen 1.
On the test drive it rode good, it was a little boggy out the hole.
Last weekend it took a little to get it started on muffs, but ran till I assumed it was out of gas since it had 1/8 tank and the angle it was parked.
This weekend I put 5 gal of gas in it, but would not start.
I pressed the accelerator pump on the Q-jet carb and it did squirt in the primarys. When I had the spark arrestor and cover off the top, I did notice the rod that runs the choke flap from the divorced choke was missing. Held the choke closed and began cranking operating the throttle from neutral and up, no joy.
Pulled plug #1, it has spark but it's a faint yellow spark.I am use to old car engines that put a nice blue spark across .045 gap or so. I also noticed the spark gap is quite narrow on the plugs, is this normal?
I put a test light and volt meter on the coil, test light grounded to the thermostat bolt shows hot on both leads on the coil, and the volt meter shows +11.8 dc on both the + and - side of the coil. From what I know of working on cars, only the + side is hot, not both leads.
So my questions are:
1. Is a faint yellow spark normal on these i/o's?
2. What is the recommended gap on plugs?
3. Where is the part number located for the carb? Is it on the red mercruiser tab attached to the corner?
Sorry for the novice questions. I spent 3 hours trying to get plug #1 back in and the socket off of it. My back and knees are still killing me from being cramped in the little engine hole.
I figure I will need to rebuild the carb and fab a choke rod from a piece of metal coat hanger. What I'm really looking for is input on the spark, and if that is the more pressing deamon to exercise.
BTW.
Merc 305 w/quadrajet, alpha one gen 1, 1.65:1 sn: 0b714730
BTW.
