OK, you guys have been quite helpful on this engine in other posts (see below), and I've been really slow in attending to it, but I'm back on task.
So, this engine hasn't been run in several years and appears to have very few hours on it, none in the water. I had some other issues with it which I hope I've resolved for the moment. And I've done the necessary things before trying to start it, changed the oil, plugs, rotor, distributor cap, oil and fuel/water filters, turned it over manually, oiled it manually, spun it out with the starter motor, etc.
It had about 10 gallons of old fuel in the tank, so I've disconnected the fuel line at the fuel/water filter and dropped a two foot line into a jug of fresh fuel.
I was initially able to start it and keep it running with starting fluid, and after a bit it will run smoothly on its own for several minutes, but then quit.
So, I'm thinking that I can eliminate the timing/spark issues and concentrate on fuel. That right?
The fuel pump pumps a steady stream of fuel when I remove the line where it enters the carburetor, so it appears to be getting fuel at least that far.
However, when pumping the throttle I'm not seeing a squirt of fuel in the venturis. Seems like I should, though, shouldn't I? It's wet in there with fuel/mist, but no stream pumping in.
I took the top off the carb thinking that maybe the bowl would be empty, or the needle valve or float would be stuck, but no, no and no.
So, should I be seeing a stream of fuel pump in when pumping the throttle? Is there a filter that may be clogged, somewhere after the fuel line enters the carb?
Anything else?
One other thing that I found curious. While the engine is running, it's blowing exhaust and water, as expected, out of the starboard exhaust pipe, but only exhaust, no water, out of the port side.
The boat is sitting on a trailer that's parked lower on the starboard side, maybe a couple inches lower, but I don't know enough about the coolant path to know if that could be the cause. Surely these things don't have two thermostats, do they?
Thanks for your help,
Jack
Inboard/1980 Mercruiser 330/almost no hours/1962 Century Coronado.
Previous threads on this engine-
Re-Commissioning "New" 1980 Merc 330
Stuck Mercruiser 330
Un-Stuck Mercruiser 330
Water in bell housing
Anything else?
Jack
