Hi, I was out in my boat yesterday and my 1986 35 HP Merc lost forward and reverse gear all of a sudden. It also stopped pumping water. I paddled back to shore and couldn't notice anything obvious. The prop looked ok, so I assume I have to pull the lower. With the motor turned off, if I put it into gear (forward or reverse), the prop engages and spins freely in neutral as it should. I originally thought it may be the shift shaft, but it does appear to engage in gear as mentioned. I think the fact that it is not pumping water as well may be a good indicator of the problem. Any ideas what I am in for?
Thanks!
Thanks!
