merc 350 engine problems need input
cobia-boat
I was on the lake today, and it was running great. Stopped for some grub, then an hour later left and no waked it for about 5 min. Hammered down and bang bang bang. Pulled off cyl. 3 wire from dist. and it goes away. Sounds like something is banging by the intake. I had 20 miles to get home so i no waked it all the way home at 6 mph. to get it home running rough on 7 cyls. engine year is mid 80's on a 23 foot chris craft pre alpha outdrive
firehog6305
Re: merc 350 engine problems need input
sounds like a valve to me, or a pushrod problem, but i'm sure one of the master wrenchers on her will help
Ayuh,........
You might try a Compression Test,.......
But,......
It Sounds like it's time to Pull the Head,+ Look........
Bt Doctur
may just be a broken rocker arm too
cobia-boat
pulled the valve cover and on cyl. three one rocker arm broken off, right at the stud, and i can't see the valve??? (where could it go?) The other valve is loose and looks like the rod is maybe bent a little. I pulled the plug and it just looked oily.
John_S
Proceed to pulling the head. At this point, you will be extremely lucky if there is no damage to piston or cyl wall, that will require engine rebuild.
Don S
Probably in the cylinder and THRU the top of the piston.
