Merc 4.3 h2o alarm sender test?
tazzerblue
Can you just ground the wire to the block? and see if buzzer sounds?
can you check the ohm reading on sender?
Thanks, I love these type of fourms.
Don S
Re: Merc 4.3 h2o alarm sender test?
Yes, grounding the wire should sound the alarm.
They are not a sender like a gauge sender, they are a switch. Either opened or closed. When they sense overheat, they close the circuit to ground.
