I have a perplexing problem. My boat starts cold with the flick of the key. If i turn it of, wait 15 seconds, and try and start her again....boom, fires instantly.
However, if i let it sit for more than 30 minutes it has a really hard time starting. IE giving a little gas and cranking for 30 seconds. I originally thought the motor was flooding, so i took it to the sand bar, shut it off, and waited 30 minutes and tried starting it without giving gas. Same thing, 30 seconds of cranking and when it is about to fire, i have to give it a little gas.
After having the hard starting problem, i took it to the dock and let it sit for 3 hours. Came back out and fired instantly. It appears i may have a heat soak problem? I know its winter blend gas in the boat, but i never had this problem with my merc 120? Is this what it sounds like to you?
