Here is my problem. 1986 Mercruiser GM 4.3L V6. Motor was running OK last season, although I noticed with WOT it wouldn't reach even 4000 rpm, and sound was kinda muffled when I put it in full (anyways, sounded different than the other one, it is twin engine setup)
Motor was winterized properly. But this spring when I changed the oil, I found the water in the oil, just a few drops, separated from oil. Did a tuneup, changed sparkplugs, wires, oil, ets. Today tried to fire up the engine on muffs. It popped a few times thru the carb, but started. Was running on 5 cylinders only. Ran it for about 5 min. than turned it off. I took the sparkplugs out and found that #2 is wet with the water. Checked the compression, and it was:
1 - 170
2 - 150
3 - 170
4 - 170
5 - 170
6 - 150
Crancked the engine to vent the cylinders, put the plugs back in, and started again. Same thing, runs on 5 only in the beginning, and died idling later. Pulled the #2 plug - filled with water, and #6 wet.
Pulled the intake manifold, and found the water in the EGR passage. And gasked between EGR passage and #2 intake didn't look good. Pulled risers, and found the water sitinng in each exhaust passage in both manifolds.
Pulled the head, there was a few drops of water in # 2, and trace of water in #6.
No visible damage to head gasket, or any visible cracks in cylinders or head.
As I mentioned, the motor was properly winterized, in fact there was still antifreeze in the water. I've searched this forum thru and couldn't find any answers. One more thing, I filled up the manifold with water, to see the obvious leaks, but there wasn't any, no visible cracks either. It is a freshwater boat. Any ideas? Can blown intake manifild gasket do it? I highly doubt that both manifilds would fail at once.
Thanks in advance.
1 - 170
2 - 150
3 - 170
4 - 170
5 - 170
6 - 150
Thanks in advance.
