Hi all.
I have the opportunity to buy a head for a decent price.
Will a 429 / 460 one work with minimal setup changes ?
Spec as follows -
Intake/Exhaust port volume: 275cc/100cc
Combustion Chamber volume: 95cc
Valve size: 2.19x1.75
Valve Springs: Single with dampner 125lbs closed pressure. Springs will accomadate .640 lift.
Flow figures: 322 cfm @ .600 Intake 195cfm @ .600 on the exhaust
a direct replacement for any 1968 through 1986 429-460 ford engine. They accept standard 460 intake and exhaust manifolds, you do not need to use Cobra Jet intake or exhaust. If you have any questions feel free to e-mail. Thanks for looking and happy bidding. these heads are comparable to Edelbrock,dart,Pro comp P-3051 same specs and flow numbers,merlin,rpm,trick flow heads.Please look in our ebay store inventory for correct roller rocker studs and correct guide plates for 80.00 or just guide plates.
Intake Flow
.100
.200
.300
.400
.500
.600
.700
59.8
115
172
243
302
322
330
.100
.200
.300
.400
.500
.600
.700
48
98
125
158
186
195
203
Spec as follows -
Intake Flow
.100
.200
.300
.400
.500
.600
.700
59.8
115
172
243
302
322
330
.100
.200
.300
.400
.500
.600
.700
48
98
125
158
186
195
203
