nola mike
- Joined
- Apr 22, 2009
- 5,524
Noticed that the coolant level in the overflow tank of my 170 was low a bit ago. Had been running fine, no issues with overheating. Coolant in the actual reservoir was fine. So i added coolant to the overflow tank, took it for a spin, saw some smoking in the engine compt. coolant had leaked out the reservoir fill cap. The level in the overflow tank was low again. Again, the coolant level in the reservoir was fine, where it was prior to me adding coolant. At no point did the temp get above 160', even with prolonged high speed running. So...
1.I noticed that the overflow tank has a cap with a nipple on it; it looks like there's supposed to be a hose of some sort on there, but there isn't.
2. When i take off the main reservoir cap and the engine's warm, there is no pressure in the system. Don't know if this is related to point 1.
is this just a problem with me needed either a new overflow/reservoir cap (where can i get one?), or should there be another connection on the overflow cap, or what? as i said, the boat has run just fine for >200 miles since i got it without overheating issues. it's an '86 with a 4" exchanger, if that makes a difference.
