Hey guys!! sorry been awhile since i posted up. Lost internet connection for awhile, almost had to sell the boat but now it looks like she's gonna stay mine!
Now, for my issue. Last year you guys had me running GREAT! Now...not so much! LOL Over the winter I took care to winterize her..or so i thought. I added stabil, ran antifreeze through all the lines. And changed the oil in the outdrive as well as engine. Upon breaking her out this year I noticed right away I had made a mistake. The heat exchanger had come apart due to freezing water. Well, got that fixed and no more issues there!
Now, took her out after adding good fuel, changed out the fuel filter, changed the oil again for shyts n giggles, checked the trim fluid level changed it, changed the lower unit fluid again. You name it. Oh, and changed the plugs too....
took her to the lake she started right up idleing nice and smooth! Went out slowly for about two miles or so letting the oil get around the engine and let her build back up or loosen up whatever you wanna call it. Now..after all that I finally opened her up slowly. She got up on plane and in less time than it takes to think about it i was at full throttle, trimmed out, and cruising along at about 51mph. I know, had the gps with me. Well, went up and around the lake around and around all the time keeping an eye out on temp..oil pressure, you know the normal stuff. Decided to go under a bridge to head UPSTREAM to by one of my old stomping grounds. Figuered in the river anything bad happen I can always float back down ya know. Well, went to slow down adn she stalled. Slowly at first then she just died outright.
Finally after I thought she was flooded I realized that if i held the top butterfly open on the 2bl carb that she started right up! No problem at all! figured ok...well she sat for a long time so lets get some fuel running through her and see how she does. Opened her back up to about 40 or so. Had the cover off since I had been working on the engine to get her running again anyway and figured I MAY have to do it again so i didnt wanna have to remove everything again. Well, after about five minutes or so i decided to slow and see how she responded. She did NOT die now..i was happy!! So i went to go again and boom! She started sounding like she had a huge air leak!! Like a whistle almost. Before I knew it she stopped making the noise BUT she started sounding like she had a rod knocking!! I stopped asap to see if something had maybe fell into the engine...nothing. She stopped making ANY noise when I stopped the boat and just idled smooth as could be. Guessing the carb issue is gone now. But worried about the motor..
Anyway figured well she's not making any noise now..hopefully she wont again. So i began to give her some gas and the nosie was gone! I was happy again..lol. But not for long. i putted around at about 20mph for at least 20 minutes. Not a sound to be heard but a perfectly running 470! Then it happened...I decided to give her some gas and see what happened. brought it up to 30 mph and she slowly started the knocking again. I about cried! Everytime I slowed down she would stop making the noise. She was at about 170degrees if that, she has ALWAYS ran cold... The voltage was fine, the fuel was definatly getting to her, and I changed everything and did all the routine stuff before I took her out!
What the heck is going on! She will drive all day long at 20 or so mph without a single knock...but you bring it up to 30 or so and she starts it again. A friend of mine says that with these engines being known to go through head gaskets that he would change that and see what happens. But to me that sounds like a long shot if I ever heard one! I have a guy who has 2 470's one just rebuilt by him for $900. Figuring I may HAVE to just accpet my losses and buy the new engine and swap her in. Kinda figured it would be worth going to a larger motor..but don't wanna do something thats not safe ya know. Way to many threads on people doing unsafe crap and getting shafted for it.
The boat is a 1987 19ft glastron. Figure its been long enough you guys MUST have forgotten that. lol...thanks for any info or advise you can give!! Will
