ErieRon
- Joined
- May 5, 2009
- 463
Gentlemen;
I have a 1984 Merc 470 S.N. 6701134 with an Alpha 1 drive.
Sterndrive S.N. 06753035
Outdrive S.N. OF161976
While on the water recently I started the engine and as I shifted to forward the boat began to move, but immediately stopped and a whining noise was heard. That shift felt normal, momentarily anyway, but the momentum stopped abruptly and the whining noise was heard. The noise seems to be coming from the transom assembly (general area anyway) as observed from inboard since we were on the water.
I shut it off immediately and checked the shift cables and they appeared to be working (moving anyway). I restarted it several times and it whined in idle. When I attempted to shift, it felt somewhat normal, but weak, tension-wise, and the whining increased as I attempted to shift.
There seemed to be light tension on the throttle the first couple of times but eventually the tension on the throttle was gone, and as I shifted it only seemed to be throttling up...then it would stall out. I couldn't even feel or hear it trying to engage the gears.
As it stands now, it is on my trailer and I am wondering where to start.
I have downloaded and read the manuals and procedures, but I am still pondering a starting point. The lower shift cable is an obvious potential cause, but I have not heard anyone mention the whining sound in this forum. I have also read up on the interrupt switch, but that seems to be related to shifting out of gear, as opposed to into gear.
Note: The outdirve is only 5 years old due to theft. The S.N above is from the original.
Any suggestions would be greatly appreciated.
Thank you in advance.
Ron
Ron
