Re: Merc 470 voltage reg symptoms?
Those charging numbers, are just fine!
Remember...the starter pulls a lot of amps, and the voltage regulator is initally reacting to the 'missing' battery amps from the engine start. Then it settles down....
I have a 470, and a 3.0L...and they both show this range.
I have a single wire alternator conversion kit, that I have never had the need to install. I just felt that it would be better to have around...for when (not if) the regulator goes south!
