RAT Attack
- Joined
- Dec 25, 2009
- 167
If there is ever a bright side to things, being towed in by your brother is much better than a stranger...
I am so stressed out right now. My boat has been running awesome for the last 110 hours, and had to get towed in to the dock today. Any help would be greatly appreciated. I don't even know where to start.
My day started off good. Launch and some cruising all was sweet in the sun. I was meeting my brother in about an hour. His boat never has problems, but did today too. His battery was dead. I gave him my spare, but it didn't have enough juice either to start his up. I then gave him my battery & put my spare back on mine ( while still running ) to let my system charge it back up. Everything was good running for about a mile or so. We stopped at a cove for a bit after I ran it & when taking off the drama began. My engine was running great, I went through about a 150 yard section of no wake ( prop. turning fine ), hit the throttle about 3/4 and it went for about 30 yards, heard a snap, and then nothing. I thought I spun the hub on my prop., so I put my back-up on, but nothing. ( ?????????? )
If I put it in foward or reverse with the throttle & not running, I can't move the shaft. In nuetral it still turns fine. I hooked it up to the muff's at the house while running, & nothing. No turn from the prop. I also tried it without the prop. on but still with the muff's, but still no turn. All of the spline gears on the shaft & hub looked perfect. Is this a cable issue, or something more serious. I know you don't know the answer, but any advice would be greatly appreciated....
THANKS!
My boat is listed in my signature if that helps at all....
THANKS!
