Merc 5.7 30amp alternator upgrade to a 50amp
mstrud
I recently replaced the alternator on my 5.7 and b/c of part availability had to upgrade from a 30amp to a 50amp alternator. When i took the boat out it seemed to run fine until the motor died. when i tried to start it up again nothing happened. no clicks or cranks. after following some wires I eventually figured out that the fuse relay to the starter solenoid tripped and needed to be reset. that started it up again but the same thing kept happening. it would run but eventually die and need to have the relay reset. I noticed that the relay was a 30amp. My mechanic didn't mention anything about the relay when i asked him about any issues that may come up with the 'upgrade' before hand. I intend to replace the 30amp relay with a 50amp but I would like to find out what other additional surprises lay in-store for me in switching to a 50amp alternator on a 30amp system.
Also on that day the boat seemed to be running fairly sluggish. The motor ran smooth but it seemed to only be running at about 70%; to get to my normal speed @ 3000RPM it took about 3800RPM. Im hoping that the mechanic who installed the alternator pulled a plug wire for accessibility and simply forgot to hook it back up. But given the 30amp/50amp issue I thought i'd mention it and see if anyone can link the two issues.
Mariners, your input please!
achris
More fish than mountain goat
Re: Merc 5.7 30amp alternator upgrade to a 50amp
...Also on that day the boat seemed to be running fairly sluggish. The motor ran smooth but it seemed to only be running at about 70%; to get to my normal speed @ 3000RPM it took about 3800RPM. ...
That sounds more like a prop problem...
Chris.......
I don't think there was ever a 30 amp alternator on 350 at anytime. I'll suggest talking to your mechanic again.
Ayuh,... 'ell, I thought 99% of 'em are 55 amp, Stock...
Or local Wildlife,.....:D
Icefire55
if it's the soleinoid breaker, it need to stay at 30A, it protect it. if you go at 50, you'll fry it.
Probably had the alternator wired wrong? what's the battery voltage while not running and at idle? should be 12.6/14.x
mstrud
The voltage is running in the appropriate 12.4-14v range. The batteries seem to charge faster. Everything appears correct except for the popping the relay and the sluggishness. But I dont believe the sluggishness is related.
lime4x4
I'm running a 140 amp marine alternator without any issues
mstrud
So does anyone have any thoughts on what is causing power to surge? The breaker hasn't popped when the motor was revving. It has only popped when the motor was at idle. Could this simply be a grounding issue?
