kssmallies
- Joined
- Aug 31, 2007
- 8
Hi I have a 67 or 71 500 also I don't know yet which year. I dont' know much about the motor but im trying to stuff everything in because its too much money to have them looked at. Anyways bought the boat 2 weeks ago took it to lake to see if it even float and the motor started right up but would only go about 5 mph when I throttled down the motor would rev way up but would not go anyfaster so I left it idiling while I checked to see if the trolling motor worked and when I went to take of again I idiled way up and throttled down and the whole motor started to shake and the boat barely moved and then died. I could smell gas real bad I tried to start several times and then boom. Blew the whole top cowling cover off the motor I think I flooded the carb because gas was pouring from them and with all the wires showing I must have made a spark when trying to start. Anyways took it back home and waited 2 days and took it back out and she runs fine without the cover on? The boat still wont' go over 5 mph though I think I spun the hub or do you think I should check anything else. Also what is the easiest way to clean the carbs just pour some carb cleaner in with the gas? THanks
