Hi all
My motor was starving for gas once I hit just past 3/4 throttle. I pulled off the cowling and gave the bulb a few pumps and could see a lot gas leaking from the low pressure fuel pump. Replaced pump and and no more leak there BUT when I pump the bulb I see gas leaking out of a small drainage hole at the bottom/front of the engine. Any ideas? I can't see where it's coming from. It's a 2003.
EDIT- is that little drainage hole possibly and overflow drainage? I was pumping the bulb like crazy to see if the fuel pump was leaking. Is the engine setup to dump fuel if too much is pumped in?
Thanks in advance.
Nuzp
Thanks in advance.
Nuzp
