I have a 2005 6.2L MPI with Bravo 3 and took the boat out over the weekend for the first run of the season. I had a couple instances of the engine stalling out while in gear at idle. It started back up each time with no problems. Other than these few stalls, it ran just fine.
I think it may have been idling a little on the low side while in gear and there were a few times where I got a wiff of rich smelling exhaust.
I did some googling as well as searching the forums and I'm trying to put all the info together. From what I gathered, I could have a fuel pressure issue, IAC valve issue, temp sensor issue, etc.
I'm going to start with the easiest first and check fuel pressure, the air lines into the IAC valve to make sure there's no odd blockages or dirty air filters, dist cap/rotor.
I don't have any TechMate/Diacom software and this might be my excuse to finally get one.
Any other ideas of what could be going on?
