Re: merc 650 65hp trouble
First of all, we need more information. There were 3 versions of the 650. The ones made before 64-71 were 4cyl with the older style ignition systems (points and condensers) and the the ones made 72-75 were 3cyl with What I believe was refered to as type-III ignitions (electronic switch box, single coil) and the 76 3cyl with a type-IV ignition (newer style switchbox and 3 coils).
Find your serial number located (between the transom clamps or on the side of the engine block), look it up on the sticky post at the top of the forum and post back with that info. It makes a difference, trust me.
The fuel could be a problem, or a symptom so I wouldn't panic yet. Here are some typical things you can look at and will probably be recommended.
MAke sure you have fresh, clean fuel with the proper 50:1 mix of oil. I also recommend premium in the older engines. Not for the quality or octane level, but for the lack of ethanol. Ethanol is a corrosive and tends to eat at the older rubber seals and hoses.
You may want to clean the carbs. It's not as bad as you think. 2-cycle carbs are pretty simple. While you are at it you may want to put a kit in them while you have them off. Also clean the filter screens and check the floats.
There should be an idle adjustment screw on the front of each carb. If you really feel adventerous you can reset it. Turn it down to lightly seated and then turn it back open 1-1.5 turns for a base setting and adjust from there. Any adjustments made out of the water on the muffs will only be a rough setting. Final adjustment will have to be made on the water.
Those are just rough ideas. Get back with the serial and year and you can get more detailed info and troubleshooting from the guys here.
