Merc 650 gear oil leak!!!
almost_nick
ok guys, I have a 75 merc 650, and there seems to be gear oil leaking into the lower end where the water pump and shift shaft is. I put brand new seals on the water pump, and New gaskets. I also put new seals in the shift shaft bushing. I checked the seals and the lower end for cracks and rough places but everything is smooth. AND STILL THERE IS OIL LEAKING!
Also when I drain the plug for the gear oil. there dosent seem to be much water mixed, It seems like oil is somehow getting pushed up through the waterpump or shift shaft, but water is not going down into the gears??
Please help!
Moody Blue
Re: Merc 650 gear oil leak!!!
Sounds like one or more seals may be installed upside down.
That would allow fluids to pass in one direction and not the other.
almost_nick
Umm. I didnt think about that. The seals in the water pump are factory installed because I bought a new one. and I followed the directions on the seals for the Shift shaft. Im pretty sure they are put in correct.
Is there anything i can buy that would show where exactly it is leaking from??
Fuzzytbay
One thought, is there too much oil in the gear housing?
almost_nick
Good thought, but im putting oil in the bottom untill it just comes out the top vent. Hopefully thats not too much. But thats what i was told to do.
I think I might take the pump off and check the seal for the 5th time, just to closely exam the lower end for small cracks or anything that would let oil through.
Any other thoughts??
Thanks a lot guys, I just wana see this fixed. Hope to god I dont need a new lower end. that would break the bank for me.
Fuzzytbay
Nope that the correct way.
I'm not sure if this would work, but you might be able to put a bit of air pressure in the fill hole of the bottom end, and look from above to see if you can see where the oil is migrating up from.
What weight oil are you useing? maybe a heavyer weight might help.
lindy46
Get a pressure test gauge on ebay for about $30. Pump it up to about 10psi and listen for leaks/spray seals with dish soap solution and look for bubbles. If it holds steady at 10psi, seals are ok.
