I just recently purchased a 1968 Mercury 650 serial #2446837 along with a Seloc repair manual. According to the manual my motor should have a type III ignition but the switchbox in my motor is the same as in a type II as is the wiring. Is my Seloc manual wrong or is it possible that I have an ignition from another motor? I'm also having trouble locating an original tach for this motor and have read that the brown wire can be moved from the switch box to one of the yellow wires on the rectifier to use a different tach. The only brown wire on my switch box goes to the mercury switch, any other suggestions that would enable me to use a different tach? The wires that lead into the switch box are as follows. Top - red wire to ignition driver: second from top - blue to ignition driver, orange from engine harness and brown to mercury switch: Third from top - white to ignition driver: last - black and green to coil. Thanks.
