Merc 650 seal question?
THEPATRIOT
"67-"69 650 prop shaft seal,are they hard to change?I found one of these FS,but the owner told me it started leaking.I realy want a 65HP motor,and this one runs good!
Laddies
Banned
Re: Merc 650 seal question?
If it's a fresh water motor they are quite easy remove the carrier nut and carrier and use a punch drive the seals out and reinstall, the inner seal the lip goes in and the outer the lip goes out.
THEPATRIOT
If it's a freash water motor they are quite easy remove the carrier nut and carrier and use a punch drive the seals out and reinstall, the inner seal the lip goes in and the outer the lip goes out.
He ran it in salt water once in a while,but rinsed in EVERY time.Should i avoid it since it's been in the salt?
Laddies
Banned
Depends on the price and your ability to get it apart
propwash
Just replaced them in my "68' 650 and took it a step further and also replaced the needle bearing in the carrier and the large o-ring,it was pretty simple straight forward stuff.
propwash.
THEPATRIOT
How's the price sound for this one?
propwash
where i'm living that is a very good deal,minimum of 10 bucks a horse here.
