Merc 650
StarTekh
buddie has a merc 650 1966>? <br /><br />SN 2017149.... please comfirm year<br />we also need points setting and correct plug number and its gap thanks guys jon montreal out :p
rickdb1boat
Re: Merc 650
Hi John,<br /><br />That is indeed a 1966 Model. Good old motor, as I had a 67' 650 that served me well. Spark plug is gonna be a Champion J4C or an NGK B7S Gapped at .030. Points should be gapped at .020... Good luck with that good old Merc...<br /><br /><br />Parts and info below:<br /><br /><br /> oldmercs.com <br /><br /><br /> Basics
StarTekh
Re: Merc 650
ok thanks for Pro info. buddie has questions<br /><br />would that be .020 mm? cause the mag has .008 inch right on it<br /><br />well, I'll stick with what the magneto says in this case<br /><br />.008 inch / 48 degree dwell<br /><br /> wana set him streight pls ty Jon :p
emckelvy
Re: Merc 650
Points set at .008"-.010" oughta Git 'er Dun in the absence of adjusting by dwell, however adjusting by dwell is more accurate.<br /><br />Cheers........ed
