Merc 7.4 MPI splutters and excessive oil usage
jezzb
Hi, I find my Merc 7.4MPI consuming oil - more than normal. When I start the engine, it smokes white a bit but nothing out of this world - only just as it fires up - and only after I havn't used the boat for 5 days or so. I read on this forum that the oil cooler may be leaking. How can I tell if the oil cooler is leaking without a pressure test? Are there any visible traces? Something which I should look for?
One more problem I have - which came up after I took the boat out of the water for the winter (no winterising done as I start the engine every 3 to 4 weeks), is that it starts OK and after a couple of second it splutters and start shaking - and it works fine for some seconds and starts spluttering again. When I increase the throttle it seems to works fine. What can the problem be?
Thanks - Jezz
Re: Merc 7.4 MPI splutters and excessive oil usage
Ayuh,... Oil in the Exhaust Water....
As for the rest of your Problems,....
I would think a Full Srevice,+ Tune-up, along with a full Compression,+ Leak-down Tests would narrow down What you're looking for....
It could be as simple as Fuel Filters,.....
Or,...
It could be Much Worse....
jezzb
I am starting to scratch my head now.... I did a total overhaul of the engine 2 years a go and it only has 70 hrs. Last season I fitted a new pair of stainless steel, one piece manifolds. The Oil usage has been there since the overhaul. Can it still be what you guys think it is ?
Thanks for all your replies
Jezz
jezzb
Thanks Bubba, I will start with a compression test and take it from there.
Kind Regards
Jezzb
JustJason
2 questions....
First what color is the smoke on start up.... Is it white, black, blueish/grey??
Second.... what brand and weight oil are you running in this motor?
krisnowicki
Thanks - Jezz
Where do you live does it get down to freezing? If so, just starting it every couple of weeks wont solve the problems that winterizing does...
