metalvolks
- Joined
- May 8, 2007
- 19
I have a 1975 7.5 Merc 2 stroke. It came with my boat (which has a 115 HP) and i've never used it. Wanted to sell it, so I did some maintenance. Replaced the water pump (impeller and everything that comes with the kit), plugs and bottom end gear oil. I ran it in a trash can for 2 minutes and not much water came of the tale tail and the water was very hot. Exhaust/water jacket cover also was hot.
I took off the power head and exhaust/water jacket cover and it was a mess under there... lots of sand and crap blocking the water path. Dug everything out and took compressed air and made sure nothing was clogged. I replace the 2 gaskets and the powerhead gasket. Also, I replaced the water tube grommet and top piece (plastic piece that the powerhead sits on to seal the water tube).
I started it back up. I have a little better water pressure, but not much and it still gets hot within 2 minutes. What is going on??! What can I do to fix it? I want to sell it and I am in the hole $120 right now (parts) and I don't want to go deeper if I don't have to.
Thank you for any help given.
Paul
Paul
