Re: merc 7.5 tell-tail?
Hi Will,<br /> Most of the water goes out the exhaust through the propeller. If your motor has a telltale/pisser outlet, it would be at the junction between the lower cowling trim piece and the lower cowling, on the starboard side. You can see easiy enough if you have one by removing the top cowling and looking for a black rubber hose running from the top rear of the motor block down into a fitting in the belly pan/lower cowling.<br />- Scott
