Ashburn448
- Joined
- Jul 11, 2017
- 3
Hi everyone, I've read a lot here but new this is my first actual post, seems like there's a lot of knowledgeable people on here and I'm hoping I can get some advice on my situation. So I have a 1959 cutter with a 1961-62 mercury 700 full gear shift short shaft motor serial number 1482689. I purchased the motor recently and it ran when I bought it but I had a couple issues once it was on the boat. The starter at first would spin but not engage flywheel. I checked bendix and lubed, checked all connections and eventually purchased a new battery. After the battery I was able to start the motor a few times but then the starter solenoid stopped working. Would not click or anything even thought it was receiving voltage. I jumped the two large wires on solenoid to check starter motor and it started every time without issue. So now for the real issues, I purchased a new old stock starter solenoid and installed it. At first it seemed like everything was fixed. The engine cranked every time with the key and then turned on. Unfortunately the starter would not shut off after engine was running. Then when I tried to shut engine off with key it still did not shut off the starter motor or the engine. Had to pull battery cable to stop it. This issue reoccurred every time I started the motor. I then disconnected the red wire leaving the solenoid and going to starter motor so I could test the solenoid. When I turn the key all the way to crank the solenoid clicks and sends 12v volts out, when. I release key the solenoid contacts open, as the should, and I have zero volts again. I tested the solenoid many times without starter motor connected and cannot get it to malfunction at all. But every time it's hooked up the starter continues to spin after engine catches and key is released and every time I can not shut off engine or starter with key. Sorry for the ridiculously long post, please let me know if anyone has any advice or I left out any important information
