random_guy
- Joined
- May 5, 2019
- 29
Hey everyone:
I've had trouble keeping my Tracker Targa running and have found quite a bit of water in the carbs. We bought it this spring and it sat quite a bit for the previous owner. We've used it a lot but have started having trouble lately.
So I bought a fuel/water separator and made a small bracket to mount it. (See this pic.) I ran a line from the tank bulkhead fitting to the arrow that would seemingly indicate "in" and then ran a line to the port with an arrow pointing "out" and connected that to the engine. I used the supplied fittings and plugged the two holes on the opposite side of the mounting base. I went to the launch and I primed and primed and tried to get the engine to start, but it just wasn't getting any gas. So no firing.
I came back home and found that the bowl was full of fuel. So I emptied it. I disconnected the line from the tank end and rigged up a small funnel and poured some gas straight into that line (the "in" arrow on the mounting base). It all went straight to the bowl.
So I emptied the bowl and reversed the lines on the mounting base for the separator and did the same thing. All the gas went straight into the bowl.
Am I being stupid here or is this thing defective? I've never actually used one of these before but it seems like it shouldn't be rocket surgery to get it to work. Advice?
Thanks!
Thanks!
