I have a Mercury 80 serial # 3052377 (1977 ? ) . The reverse lock hook only grabs when the control arm (throttle hande ) is about halfway in reverse. By then the RPMs are to high and the motor wants to jump out of the water. It is not locked at all in nuetral. I have tried adjusting the pushrod and control cables with no luck.
Is the problem in the lower unit. Scary ! Anything else I should try before I dive into the lower unit ?
Thanks ahead.
Thanks ahead.
