Re: Merc 80hp Coil test? Cost?
Yes, it is the first thing to check. you can switch two of them around, and see if missing spark goes with the same coil.<br />You can check for an open winding by using an ohmeter . You should get between 100 and 600ohms, from it's ground wire to it's other low-tension wire (accross it's coil).<br /><br />If the coil checks-out, next check would be trigger.If trigger pulse is good, coil is good, the switchbox is bad by process of elimination.<br />Anything else would manifest itself as no spark to all cylinders.
