Merc 850 crankshaft play?
hereto
Hi All,
Have a 1977 Mercury 850. I pulled the upper bearing cap today to inspect the bearing. My bearing felt fine but I noticed I have some side to side movement of the crankshaft ( right at .005 ) When I re-install the bearing cap, there is
no play. I'm thinking I have a problem!! I have been looking for slight rattle at about 3500 RPM. Might I have found it.
I sure hope this is NOT my problem. Sure appreciate some help.
hereto
GA_Boater
The bearing cap helps locate the bearing. You might need to keep looking.
hereto
I'm sorry, but I should have stated my question better.
I would like to know if there should be ANY side to side movement of the crank With the upper bearing cap removed?
Thank You
hereto
Yes of course there will be.---Bearings have clearance.--------------Remove the bypass covers and see if that helps find the " rattle " in your motor.---These covers are on the starboard side of the block.
