merc 850 no fire
ouchita
I have a 1976 mercury 850 thunderbolt with no spark. I ran the boat about a month ago it cranked up fine and ran good for about 5 minutes then it just lost power and would only stay running in neutral. This weekend i tried to start it and it would just spin over checked for spark on all four cylinders and no spark i appreciate any help
Gomer50
Re: merc 850 no fire
Here's where I would start,Make sure you have a good battery conection.Check to see if you have 12.6 volts or more on your white terminal on your switchbox with your ignition key in the on position.Check to see if your carbon tip inside your distributor is in good shape.If I am not mistaken there is a kill switch inside your control box than can be defective as well.Possible brittle wiring insulation causing a short.Your coil maybe at fault as well.If worse comes to worse you might have a bad trigger or switchbox lets hope not $$$$$.
emckelvy
A 1976 850 has "type 8" ignition with (4) coils, one switchbox, no distributor. Is this what yours has?
If so, there are a few things you can do to troubleshoot. Disconnect the (2) stator (yellow) leads from the rectifier and see if that makes any diff. If so, replace the rectifier.
Disconnect the kill wire from the switchbox. Should be a black wire with yellow or white stripe. Some older models had an orange wire, you can tell this is the kill wire because it'll also be tied into the "mercury switch" which shorts out to kill the motor if it's kicked up by an underwater obstruction while underway.
If you get spark with the kill wire disconnected, also check for voltage on the wire with the ign switch in the "ON" position. Voltage on this wire will ruin a switchbox and is most likely caused by a bad ign switch. This wire grounds the switchbox with the ign "OFF" and so should be a Dead Short with the key "OFF" and infinite resistance (or extremly high resistance) with the key in the "ON" or "START" position.
Disconnect the Hi-Speed and Low-Speed stator windings from the switchbox and do a resistance check.
Disconnect the trigger wires from the switchbox and do a resistance check.
If all the above appears normal, most likely is a bad switchbox. Highly unlikely that all four coils would fail simultaneously.
You'll need an analog or digital meter for the resistance checks, Sears is a great place to find a meter on sale. Even an inexpensive one should be up to the task.
Here's some troubleshooting info and resistance specs:
http://www.boatpartstore.com/mercreadings.asp
http://dolphinmarineservice.homestead.com/ign5.html
Here's a wiring diagram for a 4-cyl ADI motor:
http://www.maxrules.com/oldmercs/Wiring/1966ona/80_85_5582561_BACK.gif
Anyway, that should get you started. Recommend a service manual for any advanced troubleshooting. HTH & G'luck........ed
Gomer50
Stand corrected on the distributor a little different than my older ignition system.
ouchita
Thanks for the information I will try to work on it some this afternoon I will post back as soon as i find something
ouchita
Looks like it is a bad ignition switch. had a coroded wire that was shorting out against the housing thanks for all the help
trihull59
can you take a picture of what you are talking about i have the same motor and it is doing the same thing
