jusfloatin
- Joined
- Jan 6, 2008
- 295
Good day to all
I purchased this boat several years ago as a project.
When I pulled the motor off the boat to be painted, I had to unhook a oil pressure line ( 1/8 black plastic line ) which was connected in the same spot the pee tube would normaly be hooked to. ( the dash does have a oil pressure gauge )
The pee tube was not hooked up.
Anyways after doing the restore I hooked it all up the way it was and started it with muffs on. I did not know the history of the motor and I never did hear it run prior to this so I will admit I had concerns if the water pump was working as the gauge did not move and I was worried I would pooch the motor so I decided to shut it off.
After some help from this forum I was convinced to clean the pee hole change the fitting to accomodate the pee tube and try it again. Which I did and she peed like it had been holding it for a while.
I ran it the whole summer that way and no problems.
My questions is though, if I was to change it back to the way I got it, no pee tube but hooked to the oil pressure gauge.
1-What should the pressure be?
2-Would running it like that make the motor run warmer?
3-Can a tempature gauge be add and where would I connect it at?
4-What is a good running tempature?
This is a 74/75/76??? Merc 850 Thunderbolt
