mercuryman48
- Joined
- Apr 6, 2008
- 33
Hey guys. I have a 850 merc that i replaced the timing belt on and now cant get it straight...When putting back together i brought the #1 cyclinder to TDC and installed the flywheel with the pointer at the 0 degree mark on the flywheel label. By the book your supposed to put the magneto pully mark to line up with the straight line on the flywheel....When i do this my distributor rotor is pointing straight away from the #1 Tower on the dist. cap and is pointing at the #2 tower...and it will not fire....So....i double checked my TDC and rotated the magneto pully (with belt removed so as not to disturb TDC) until the rotor points directly at Tower #1....it starts but is at extremely high idle and wont go under throttle ...dies under load ...any ideas ....getting bloodshot eyes and the twitches here !...lol....thanks ahead of time for all your input
