Re: merc 850 trim tilt diagnosis?
MercMark, I do not know an easy test to determine if the piston seal in the cylinders is bad or the valve body is leaking. However, you can narrow it down as follows:<br /><br />The cylinders are connected in "series", such that if one has a leak in the piston seal, the motor will "leak Down". If you disconnect one cylinder and plug the lines, and the other one holds pressure, you will have found the problem. If it doesn't hold pressure, reconnect and bleed it, and disconnect the other cylinder. If it still doesn't hold pressure, it is likely the valve body.<br /><br />I have had two piston seal leaks in 25 years, and no valve body failures. You can probably still get the cylinder repair kits from
www.dougrussell.com, however a special tool is necessary to install the piston into the cylinder. Alternatively, if you can find a used cylinder, it should be cheap enough to just replace it.
